What bit should I use for resurfacing my wasteboard ? Thanks!!
The biggest one you can get that allow the RPM you intend to spin it.
Set stepover to 80% vs the standard 40% Easel use. This reduce time skimming the waste board. I use a 3/4" straight flute bit intended for routing wood.
