Is there anyway the programming can be changed so that the bit gets raised higher than the plastic holders? I put my holders in place as not to interfere with the carve but depending on where the carve ends, the bit will hit those holders causing a breaking bit. If the programming can be changed to raise the bit 1/2" during the setup “raise the bit” and after the final cutis completed will keep the bits from hitting the holders.
Sounds good. I will have to mess with that a little soon. I keep walking away and bits are snapping in the material holders.
