Bit Selection in Easel
Is there a way to select a different type of bit? I purchased several bits from Inventables (compression, downcut and an engraving bit) and I’m wondering how I select the specific bit in Easel. I have messed around in Easel and only see the area where you can manually type in the bit width. Am I missing something or are the Upcut, straight and V-bit options the only ones preset?
Just select based on the size. If it is an 1/8” then select that. Do not be concerned if it is an uncut or downcut and so on.
