Bit size for high detail stl files
Hi what bit size should I use for high detail stl files found on ebay?
I may be wrong, but I believe 1/8" ball nose and 1/16" ball nose bits are the preferred bits…
It all depends on the level of detail and the size of the carving.
High detail small carvings I use a tapered ballnose with a 0.5 or 0.25 mm radius tip…larger carves/less detail I use a 1mm or 2mm tapered ballnose.
I used a 1/32 ball nose for the seahorse I did.
