Bit size too large but no red areas flagged on 3D Preview
As the topic says, I’m getting an error coming up for my bit size being too large for the project, but there are no red areas flagged as too small in the preview for Easel. Has anyone else encountered this?
Yes, I had a short/small, almost unseen, vector line left over while editing Inkscape/Easel. Once I removed that it worked fine. Suggest checking really close for any small lines/objects that you may not have noticed.
@YawString I’ll inspect it very closely but it isn’t likely because I’m using the image trace tool to import a jpg I designed in Photoshop.
