Hello. I finally assembled the machine. I was wondering what bits do I need in order to carve out fine detailed artwork to a very small piece of wood, a 2"x 2" wood block.
I’d recommend a 90 or 60 degree V-bit
depending on the details, the best way to go is a tapered ball nose cutter.05 mm tip
It Depends.
For 2.5D then what Jonathan said: V-bits
For 3D reliefs than what Ken said (showed) : small tipped Tapered Ball Bits.
