Blog for ongoing project : wooden clock
I started working on a wooden clock, http://lisaboyer.com/Claytonsite/medievalrackpage1.htm (plans bought from from Clayton Boyer). The blog is here :
Blog
The blog is in Dutch, but it has some pictures :wink:
All the pieces are being made with my x-carve, and it is going well until now. I am using Birch plywood. The only issue I had until now, is that the cut is not 100% clean on the bottom (tearout), since I am using a downcut bit.
Compression bit is not an option, since I am using a 1/16th inch bit a lot (they do not seem to exist for such small size).
Overall a very fun project, I hope it will work in the end :smile:
Nice, just wish I could read Dutch. But I did enjoy looking at the pictures.
That is awesome! Looking forward to pics of your own build!
Nederlander of belg? :wink:
Mooi werk!
Belg :slight_smile:
bedankt,
Kris
I added a translation widget, I thought it would be awful, but it is not too bad actually…
Thank you,
Kris
The pictures in the blog are mine, they show what I did until now.
Thank you,
Kris
Oh wow, great job!
I’ve successfully used a 2mm straight 2flute bit to cut lots of gears. Relatively cheap too…
I also tried straight flute bit, but then I had tearout on both ends (with plywood)…
Hmmm.
I had to try adjusting the feed, but I’m sure you’ll work something out.
