Blue Border
I purchased a stl file online and when I loaded it onto Easel there is a blue border that cuts off the fingertips. Is there anyway to resize the image or away to make the blue border larger?
Can you show a photo? Including the right side panel with the settings?
Screenshot 2023-02-28 122359
Screenshot 2023-02-28 122518
After you asked for more photos and rotating it. It appears that maybe the blue line is deceiving looking at the stl straight on. I’m thinking it’s all good.
Yep, that rectangle by default is perfectly aligned to the model, which looks to be behind the model and then appears to be kind of inward of the edge of the model from certain angles. But yeah, you’re good like that However if you are flattening that rectangle are you may need to set a thicker Padding area to ensure the bit can get down in next to the fingers… just my 2 cents on hopefully getting the results you want the first time around :slight_smile:
Thank you
