Has anyone bolted theirs to their work bench, I have mine on a custom sized shop table with rollers on it and the top is melamine so it’s slick enough where the machine can slide easily. I wanted to mount it to the table but was curious how other people did theirs. Thanks guys.
I do believe quite a few people have bolted them to the table. It should not be a problem unless your machine is moving so fast as to translate momentum during direction changes to the table with wheels. I know we are getting close to Halloween, but nobody wants to see an X-Carve moving across the room on its own…
I put some rubber feet on mine…
{:0)
Brandon Parker
Just be aware, that when you bolt it down, if there is any variation in your table it can twist the X-carve slightly. This will cause traming issues.
