I have searched for details on where to mount the Bosch spindle mount to it’s plate. This detail had been left out of the PDF document found here: https://www.inventables.com/technologies/bosch-colt-spindle-mount . I found this video on Inventables youtube channel https://www.youtube.com/watch?v=Raty-ijFP0c that shows the mount being attached to the middle of the plate with two inner holes at around 1:30. After mounting this way I noticed that these two bolt heads are going to interfere with the delrin Z nut as it moves down the threaded rod
I guess it should go in the two outer holes that will clear the z nut block, but one of the holes is bigger because it’s on the side with the eccentric v-wheel adjusters. I guess this will allow some adjustability to square the spindle to the table. Does anyone have any suggestions or helpful links I may have missed? Thank you!Edit: I realize now that the delrin Z nut is bolted to and moves with the spindle mount, so there will be no interference. #noob
