I was going to make a box using the Box App. Before I start cutting my wood, I thought I should ask.
When You enter the D, W, and H of the box. Is the Outside of the box or the inside?
It looks like it might be the outside. If that is the case I need to add 1/2" to each. (1/4" material)
Yes, it’s the outside dimensions. Make sure that it is set to outside cut, also.
