is there a way to turn off the box that keeps popping up when you put your numbers into easel like when you are typing in a location or size or depth. it is always in the way you have to click a number in it or somewhere off the box to make it go away. dont use it dont like it.
The box circled in red or the one with the green arrow?
Actually I guess it doesn’t matter because the answer to either is no, the box (both of them) will always be there… you can drag the shape/cut box elsewhere out of the way if you need, but you will surely need to use the settings in this box at some point…
