Hello - I can’t seem to find a good template for a butterfly or bowtie inlay/key. Does anyone have a good template that I can load in Easel? I’m still pretty new, so sorry if there is a simple way to achieve this. Thanks!
Maybe something like these … ? These are cut on the outside of the path so that if you carve one as a pocket the inlay should fit with minor sanding. You could use the inlay app if you want to go that far.
{:0)
Brandon Parker
