Calibration Suggestions?
Hi All,
My X-Carve is cutting well, but I noticed 1/16th off today on a 10" part.
Does this seem normal? What kind of tolerances are you all happy with on your end?
I see calibration instructions here: X-Carve Instructions: Calibrate
But if anyone has any other suggested instructions or links I’d really appreciate you sharing them.
Thanks much,
t.
Check out this video on calibrating your machine:
A well calibrated, stock X-Carve can have a accuracy between 0.07-0.13mm.
Any flexibility/slack will add up, if you tug the end mill with say 5lbs of force, how much does it deviate?
Thank you @cg49me and @HaldorLonningdal for your replies.
Much appreciated.
t.
