Calibration time - how to access GRBL from a Mac?
I’m in the final stages of x-carve calibration, and need to adjust my steps/mm - over a 750mm travel path I am consistently 0.75 of a mm out on my X axis.
There’s a bunch of troubleshoots on this forum and Youtube demonstrating how to adjust the steps/mm coding, but i’m not finding a critical step - how to access GRBL from a Mac.
I’m all ears if you have the solution :slight_smile:
What sender are you using? (What’s the program you use to commuicate with your X-Carve?)
Hi Neil. I’m using Easel.
Go to Machine --> Advanced --> Machine Inspector. In the console, type $$ to retrieve the current grbl settings. The steps/mm for the X-axis is the value of the $100 parameter. To change it just type $100 = (whatever new value you want), and it should respond with ‘ok’. You can check if you want again by typing $$. Those values are stored in non-volitile memory, so changes will persist across power downs and resets.
Brilliant!!! Thank you so much :sunglasses:
No problem!
