Trying to make a PCB and exact depth is critical. GRBLcontrol will make the heightmap file, but would like to bring it into Easel to do the actual carve. Much prefer Easel to work in over the GRBLcontrol program. Thanks
Easel does not currently support adjusting its GCode output to account for a heightmap of the stock. You would need to export the GCode file from Easel, combine the GCode & heightmap data in a separate program, and then you could use Easel to send the resulting GCode.
{:0)
Brandon Parker
Thank you
