Can I change the zero position to the middle of the y axis?
Hi all,
I am carving guitar bodies and top plates and i need the seam of the book matched boards to be EXACTLY down the middle of the carve. If i orient the wood on the machine so that the seam is parallel to the x axis, is there a way to set the zero position in the middle of the y axis? In other words if the wood is 14 x 18 inches and 0,0 is the normal zero position, i want to start at 0,7 position so tge work is centered on the seam.
Thanks,
Dave
You can manually move it there and it will hope the position to do multiple runs. When you power down the machine you will lose the position. Take a look at these videos on the topic
I was doing this on image trace but I also discuss production run
Cool! Thanks very much!
