can I import a pdf fiel.
No
No, but you can convert a PDF to DXF. Some Cad programs will do it and there are converters online. Here’s an example that I just googled and linked…no experience with it.
Try this one, depends on the content of the PDF. If you share your file we can help. Steve
Convertio
cresendo.pdf (54.9 KB)
I am trying to convert this to .svg for personal use in easel. How can I do this
Thanks
I was able to do it, but how do I separate it so i can adjust all the depths of cut? So the black crescendo arrows are the raised portion(not carved) and the white ones are carved
You can play around from here with the offsetter app to change the width of your outline
Thanks for the assists
