If I am in the middle of a job, can I shut down temorarily and resume later at the spot where I left off? I am leary of letting the X-carve go while totally unattended.
For example, working on a long job, say 6 hours, and I must leave my shop. I know I can pause Easel and resume. Can I also stop my spindle with the switch and restart the spindle and Easel later. Will this do any damage to electronics or will I lose position after a long pause.
(I have set my computer to prevent shut-down or sleeping from keyboard inactivity - learned that lesson with my old 3D printer.)
Is it possible to stop and start when using chilipeppr too?
oh yes you can i have paused and then come back up to 12 hours later just make sure not to shut your computer off or unplug the usb on the tiny g controller
also make sure that your coumpter will not go to sleep
I am not sure about chilipepper but i imagine that you can i do it with Universal G code sender all the time
also personally i was leary about leaving my machine when it was running to when i first started but really confidence in your clamps, desgin, and machine needs to be had
I retouinly leave my machine runnning and go to work and come home to find the finished product waiting for me lol my neighbors probably hate the router noise all night but oh well
really the worst that can happen to a unattended machine is:
broken bit
machine crash
work piece coming loose
really there are protection built into the machine for thermal overload so it wont burn down your house or anything
now i have the dewalt router so i have to manually turn it on (until i put a controller on it) which means that i have to manually turn it off but the dewalt router has thermal protection as well and if you really want to turn it off figure out how long your cut will take and get a outlet timer to shut it off after a certian number of hours
but if you have a inventables spindle then this is of no worry
just remeber to check check check and then triple check all your:
settings
desgin
work piece
and machine before a long cut
and there will be no issues leaving it be with you away
Leaving the machine running unattended is pretty dangerous. If the gcode does something unexpected, the bit binds or a stepper stops moving the bit can easily generate enough heat to start a fire. There are not any sensors or fuses or thermal overloads that will detect and prevent that type of fire.
Sure if the machine is well maintained, the work is clamped adequately and you are sure the gcode has no errors then the possibility of really bad things happening is greatly reduced. But I don’t discover most electrical/mechanical problems until they cause something to break. And so far things have only broken while the machine was in operation.
It is also not recommended to leave the motors engaged and idle for long periods of time, they can get pretty hot just holding position if you leave then on long enough.
My advice would be to never leave the machine running unattended.
I have not examined the electronics to look for thermal protection, I have no idea what the Grbl board has in the way of thermal protection.
But the greatest risk of fire is not from the controller board, but from the 20,000 rpm bit spinning in wood. My comment was that the system does not have any way of detecting or preventing a fire caused by the friction between the bit and work material.
well that is a potential hazard i wonder though how often could that happen? if at all?
I guess if something happened to the gcode where the bit plunged all the way through the bit and the collet was spinning on the material or you were using a big bit and something happened but i would say that its highly unlikely to happen i think if your gcode is doing that you have bigger problems but defiantly should be taken under consideration as a possible scenario
The more likely bad event would be that a belt breaks or a pulley comes loose so the spindle is stuck in the material and cannot retract or move correctly.
I broke my Z belt just a few weeks ago. If that had happened with the machine running unattended it could have been very bad.
I tried to do this one done while doing a long carve. Paused in Easel. When I came back, easel was asking me how the job turned out, as though it had finished. The project was spoiled, as I couldn’t continue from where I was.
Thanks for all the comments, lots of food for thought.
WhileI have confidence in my system, I have also had a few errant movements of the machine that I was able to stop because I was there. Not sure what may have happend if I was away.
I have smoke detectors in my shop, but still, I will err on the side of caution and run mostly attended except for small breaks. It sounds like I can pause in the job and turn my spindle off and return later, restart the spindle and continue. As also mentioned, keeping the computer active during the away period is a must (change your settings appropriately (I have a customized “CNC power setting” I use on my computer). Using E|asel or Chilipeppr give me one more concern in being browser based, it is one more potential program (my browser - Firefox) to crash during the “pause”. Maybe a stand-alone gCode processor program would be a good option.
So, I will monitor when possible and use “pause” when not possible to monitor the running machine.
Ha. One of the first accessories I bought for my X-Carve. I watched my neighbors house burn down when I was a little kid and it is still one of my biggest fears to this day.
I installed buttons for cycle start, pause, and cancel. I pause my stuff all of the time (I use UGS as my g-code sender) with no issues. I am a big fan of keeping the machine under almost constant observation while it is cutting. On my old machine I had some MDF catch on fire when the machine got confused (computer locked up) and I was glad I was there when it happened. It only took a minute to go from smoking to flames with the router spinning away mindlessly with the bit buried through the board and into the wasteboard.
