I normally buy my cnc files and such. I need to turn this into a cut file to make a sign.
Any help or advice would be awesome.
Here is one way of doing it. Depending on how you want the Tree of Life left, makes it different. The design below has two options for the sign cutout: one leaves the tree proud of the sign surface, the other has the tree as a negative to the surface.
This example does not use any of your imagery. It uses what I already had (the Tree of Life) and Easel shapes & fonts (one is a Pro font) to get close to what your image looks like.
{:0)
Brandon Parker
wow, pretty impressive work with that file. I like the multiple layer of carvings.
