Can the drag chain be mounted on the other side?
I am in the process of building a cabinet for the my X-Carve. The problem I am having is that I want the dragon chain on the other side. (If you are facing the spindle I want it on the left versus the right). Is this possible? I ask because the bracket that hold the dragon chain looks like it would only fit on the one side. Can I buy a bracket that works on the other side? Any options/suggestions?
The drag chain can be mounted in the right or left of the Y axis. Then you set the X axis to the correct direction.
The bracket that holds the drag chain will not work on the other corner unless I re drill it (which I didn’t want to do). I know how to switch everything else, the bracket is the only thing I’m having trouble with.
I have mine mounted on the left side. If your facing the machine.
