Can this be used with arduino?
Any one have any ideas on this and if so how could it be implemented http://www.automationtechnologiesinc.com/products-page/cnc-parts/touch-and-tool-probe-quarter-inch-shaft
http://www.automationtechnologiesinc.com/wp-content/uploads/2011/11/touchProbe.jpg
I have a similar one (home made) for my mill (not CNC). It just puts out a single, signal high when triggered in any axis (XYZ) so it should be usable with GRBL. I don’t use mine on my X-Carve as it’s too tall to fit between the spindle and the wasteboard
Use as touch probe for mapping objects.
Like a 3D digitizer?
Yeah there was the word that has eluded me.
That one is working with serial port pins looks like. You can read on Manual.
thanks I had overlooked that in my late night adventures while trying to elude the sand man.
you could use it but it would require you to change things a bit.
If you are interested I could supply you with the changes needed.
The manual mentions a parallel port. The circuit diagram shows it to be a normally closed switch so connections should be straight forward.
