Can u make easel pause each time before it plunges/lowers
I am a newbie to the cnc stuff, I was wondering if it is possible to program easel to make the cnc pause before it cuts/plunges. Thanks
Can you elaborate more? Pause before every plunge? Why do you need a pause? What are you looking to accomplish?
You can pause it manually if that’s what you mean
I was wanting to use easel to draw/power an oxygen cutting torch cnc. I needed a pause for preheat so it will pierce. once the cutting has started its no problem.
