I am trying to use the Easel App to design a roughly circular cut through very thick material. This will require several bit changes. My problem is, after changing to the second bit, I have exceeded the machines ability to raise the bit out of the material to a safe height for movement to the location Easel has determined to begin cutting. I need to be able to set the machine to simply begin cutting at zero. I don’t know how to set/modify the tool path to achieve this. Is there a way?
