Decided to start using my X-Carve again after a long hiatus (had a kid). Before the kid was born I bought the X-Controller upgrade. I hooked it up the other day and am now running into a host of problems, I’ll try to separate them out, but someone should really do an end-to-end software setup for folks that want to do more than just stencil art in Easel (just say’in).
ISSUE #1 - Can’t connect using UGS
First things first:
- I did use Easel to connect to the machine X-Controller and went through the configuration steps
- I have downloaded every IDE and driver in the book.
- Machine worked fine with g-shield and Arduino board.
- Setting up Chillipeppr + JSON server works (more on this later)
All the components that I can tell that are involved in getting a computer set up on the X-Controller:
- G-Code sender of some form
- Drivers to recognize the X-Controller board (not Arduino based?)
- GRBL software on the X-Controller board to translate GCode to machine movements
Laptop and Software:
- Surface book 2
- Windows 10 (latest updates)
So, for the issue(s). I have tried to connect both the Platform and Classic versions of UGS to the X-Controller using the cable that was supplied with the X-Controller. Serial Ports are never recognized. I have installed the FTDI drivers, I have installed the latest Arduino IDE which includes Arduino drivers. When I turn on the X-Controller and plug the cable into my laptop, it recognizes a device change in device manager and shows a new COM component. Any attempt to point that device to a new driver fails to update the standard USB driver for the device. For some reason I can’t pick a specific driver file in Windows 10, only a directory to search. Any time I try to open UGS classic 2.0 it says no serial ports found. Any time I try to open UGS platform 2.0 it is always in a disconnected state. I have tried to manually set the port to COM3 with the 115K baud rate, but nothing is ever recognized.
If anyone has experience getting UGS to run with the X-Controller I’d love to hear the steps you used to get it running.
ISSUE #2 - Grid is now in negative space
When I connect to the machine using Chilipeppr and run a homing command ($H) the home position is always deep in the negative plane. It seems that the new X-Controller thinks that home is in the upper right hand corner of the machine. I don’t really want to switch all my homing switches around to make this work. Is there a way to set up the machine so the “bottom” left hand corner is 0,0 and make all movements in the positive quadrant plane? This would make life a lot easier…
Thanks all.
