As the title says, all homing works except X, with the machine stopping on the belt clips (which are snug against the metal plates on both sides) before it comes anywhere close to hitting the homing switch. It’s well over an inch away at this point.
This is after doing both belt and Z upgrades to a 2020 machine. Has anyone else had this problem?
You can also remove the brackets and replace them with small zip ties around both parts of the belt. They are less bulky and allow the carriage to pass over them
