that’s supposed to be two triangles and a circle, i tried tighten the belts and adjust the motors without any change, any ideas what it could be?
update, i checked the pulleys and they were stiff with no free movement, i tried tighten them to see if the screws were loose but they wasn’t i checked the v wheels and they seemed to be ok, i then tried to mill a square and it looked okay then i tried to make a circle and suddenly it makes circles that looks like circles, any ideas what could have fixed the problem?
Do you have the same problem with squares? Try running a simple square with 2 - 3 depth passes. You will easily be able to see if the problem is with the X or Y axis and work from there. It’s difficult to troubleshoot complex shapes.
