is the mounting bracket for their machine interchangeable with the x carve mount for the router?
the reason for the question is the and I am sure I am not the only one who has a problem with how the dust shoe mounts and the brackets for the dust shoe, they cock sideways when tightened up against the mounting bracket.
If you have the newer bracket for the X-Carve and Makita combination then that aspect of it will work, but it is unlikely that the Spindle Mount to Z-Carriage bolt pattern will be exactly the same. You would need to take a look at both schematics to compare them.
{:0)
Brandon Parker
