I don’t like the knob on top. It looks tacky and out of place. Why not a momentary switch that controls the Z axis? Move switch up to move the spindle up. Push it down and the spindle moves down using the stepper motor itself.
Also, wont the motor be difficult to turn when there is power applied? Would it mean that the machine will have to be fully shut down to move the Z axis? A limit switch can be used for homing.
@OlegDzundza an electric switch negates the purpose, for that you have control in Easel, UGS or ChiliPepper. You need the knob for intricate turns to raise or lower it a hair.
See link Z-Cover w/ Knob for video in action
You can not control a stepper motor with a simple switch the way you can control a DC motor with a double pole double through switch. You have to go through software and the stepper driver. That is what jog controls are for on you control software…
A knob on top of the Z axis lead screw can only be used when there is no power to the steppers.
Actually, it’s not going all the way down, seems like short thread. I used couple of flat washers. After using this knob, I can’t make without it. So easy to go up and down after shut e-switch off.
If you look at or print the design I posted Z-Cover, you will see my design attaches to the nut, not the thread. Also a knob is never to raise or lower at great lengths it’s to move it a 10th or so of a millimeter to perfect your zero and yes if you really want to twist large amounts I advise shutting off the stepper.
Not a good idea. disconnecting the stepper from the stepper driver with it powered up can destroy you stepper driver. My Gecko G540 4 axis driver give a big warning to NOT disconnect with power on.
Unfortunately I don’t as the costs outweigh the worth, But the stl files are there if you follow the link and can have a company like 3dhubs or shapeways etc to print it for you. The issue with 3d printing much like cncing is the time requirement of the job. But it’s a nifty upgrade and both keeps the belting clean and allows you to make those micro moves.
