Carve on a arched suface
can you carve on a arched surface like a wine stave?
The short answer is yes, but it can be complicated. The regular Easel software is not designed to do that. You can do it as a 3D model if you have the skills to make your design match the curvature of the stave. Other than that, Gcode systems like Mach 3 allow for surface mapping with a probe and then you can map a flat carving to conform to a curved surface.
