Good day to you,
Please advise where can I find the Xploder app and inlay app. for Easel Pro.
John A
Good day to you,
John A
When the screen shows up on Easel over to the left side there are 7 icons it would be the one right below this guy.
I can create the rectangles easily enough. and I can draw the line drawing of a circle but there appears to be no means of trimming the unwanted cut line using the shapes function does not allow me to form a 1/4 circle line connecting with the straight lines at the corners.
Easel dont support a âtrim toolâ often found in CAD-programs.
You can make a 1/4" circle by draw a full circle, then âblockâ out the unwanted 3/4ths by rectangles set to zero depth. When they are combined with the circle they are subtraced.
Hello Haldor,
thank you very much for the instruction on creating 1/4 circles. I am not sure about combining the circle and the zero depth rectangles though.
OK I have applied a bit more thought and figured out the âblankingâ.
Best regards,
John Attwell
When you have selected two or more objects and right-click them youâll have a Combine-option available. Think âGroupingâ. You can not however Combine and âde-groupâ into the original state.
Where can I find a puzzle chair dxf file
It is definately a good advice.Thanks for the elaborated information.However, I have another query regarding the Arlo Q.My Arlo Q is not accepting to connect with Alexa and Google wifi.I have tried out for the factory resetting as mentioned in arlo app for pc . It doesnt seem to work.Does anybody have any recommendations or explanatory solutions or tips to get rid of this discrepancies?
