Carving stops part way
For some reason my carving stops part way through. The spindle is still rotating. Anyone had this??
Many have.
USB being the weak link, prone to pick up electrical noise from the router/spindle.
https://discuss.inventables.com/search?q=machine%20stops
Hi
Not using USB, I have a remote SD control box so not connected to USB cable.
Can you elaborate more on what is occurring? Is the machine always halting at the same spot? Does it happen at random locations? Have you tried it on multiple projects?
Have you checked whether $20 - Soft Limits is active? If $20=1 and your machine is traveling outside of the defined size, GRBL will alarm.
… It could still be noise though …
{:0)
Brandon Parker
