Yep, if nothing happens, download and install java, and try it again
ok doing it now.
Usually if Iâm doing something new for the first time, Iâll run the machine without a bit, and I wonât turn on the spindle, just so I can get an idea of what the machineâs going to do. You might want to give it a try for the next step. If you do, for the part where I say âtouch the bit to the work surfaceâ, just lower it so the bottom of the spindleâs about 1-2" above the surface.
Hereâs the .tap file I used just to test if my machine would move correctly, if you have one prepared go ahead and use yours.
PhotoVCarve.tap (847.3 KB)
Iâm not super familiar with UGS, so someone else might have some better suggestions, but this is what I just did and it started cutting as expected, so here we go:
- select your com port
- set rate to 115200
- click open
it should show some red text under âActive Stateâ, thatâs fine
go to the âMachine Controlâ tab
click the $X button
it should say âCaution: Unlockedâ at the bottom and the red text on the left should turn normal -
click X+, it should move to the right
I recommend you switch to âmillimetersâ when moving the Z axis
move the bit to the bottom left corner of your piece, and lower it so that itâs touching the piece
click âreset zeroâ
go to the âFile Modeâ tab
load your .tap file
start your spindle/vacuum
get ready to turn off the machine if something goes haywire
- click âsendâ
if everything worked out it should start making a series of diagonal lines. If youâre just running a test pass, you can click cancel to stop.
when I tried to downlod the java script I get something that is Pconverter-Pconverter.com, is this correct?
Nope, it should be âjre-8u45-windows-x64.exeâ
Go here http://www.java.com/en/download/manual.jsp
and click âWindows Offline (64-bit)â
ok, I had just found that when you replied, back with you soon.
ok, it said I have successfully download java. I went back and clicked on the start-windows.bat and so far nothing has happened?
After you downloaded it, you ran it and it installed and everything?
I think so, let me confirm all you said. Remember, Iâm old and there is a big dark area between my ears!
If it installed ok, you should have a folder called:
C:\Program Files\Java\jre1.8.0_45\bin
and there should be a bunch of files in there, including java.exe.
Also, you should be running the âstart-windows.batâ file from the folder that was created when we extracted the contents of the zip file, and you shouldnât be running it by double-clicking on the zip file and clicking start-windows from there. If you try to do it the incorrect way, I think it pops up a small window saying âthis application may depend on other compressed filesâ.
boy, my head is spinning. I have under C:\Program Files\Java a file labeled jre1.8.0_45
ok found all that, looking for the java.exe file wait one please
donât see the java.exe but there is one labeled java and it looks like it has a steaming cup of something on it.
Ok, thatâs a good sign. Letâs go back to your Downloads folder, find the âUniversalGcodeSender-v1.0.8.zipâ file, right click, and pick âExtract Allâ again. Except this time letâs put âC:\UGSâ (without the quotes) into the little text box that comes up, then hit âNextâ.
After that runs, it should pop open a window to âC:\UGSâ and you should see the âstart-windows.batâ file again. Letâs click on that and see what happensâŚ
ok give me a minute, trying to find down loads folder. Iâm a mac man, pcâs are new to me.
alright, I,m not having any luck with this and I am pretty tired about now. I really appreciate all your assistance tonight but I think I need to stop for a while and give it a rest. I will review all youâve given me and see if I can catch up with you later tomorrow. Thanks again.
You bet, have a good one
PicEngrave Pro 5 is almost have the price as PhotoVcarve and has more options like Ellipse & Crop an image and includes profiles for spindle & laser engraving photos. it has itâs own image editor also. We also offer a very reliable, easy to use gcode streamer called PicSender for very large, fast changing raster gcode files for engraving photos using grbl.
I didnât see any demos for bit carving. Theyâre all for Laser. Am I wrong?
