When you have a tool path for “bit” and a tool path for “detail bit” selected, you end up with two distinct cuts. is there a way to only select the detail bit tool path without selecting the bit tool path first? i want to skip the over the bit tool path because the depth of the “bit” will be accomplished in a different carve. the selected circle will be cut down on the compass carve to .1"
the second carve id like to do is v carve the letters raised but i don’t require the v bit to cut the already trimmed .1 area, but i do require the v bit to start cutting at .1 instead of 0.
i hope this is clear enough, really my only issue is that i don’t want it to take 6 hours for that v bit to clear out that .1 area with its already cut down.
any suggestions?
thanks in advanced
