Center on Object
Hi There,
I did a search and couldnt find any info on this…
If I wanted to set machine origin to center of an object, is this possible in easel?
Like setting home to the center of said object?
If not, would this not be a usable feature for placing objects on materials that are weirldy shaped ?
I apologize if this has been answered, but any clarification would be great!
Yes, it is
click on the shape and check out pop up (window setting)
I don’t understand…
I’m very sorry…
Can you explain in detail please?
its not totally intuitive due to the simulation pane only showing 1/4 of the simulation… but this is how and i do it on just about every carve…
select your object/project
under shape is the position, you can put your preference or XY0 of your workspace.
