Is there a way to have the start point of a carving to be located in the center of a circle rather than the left bottom corner? I need to have exact registration on items that are already a circle.
Thankyou.
Thankyou.
Yes, set your home position to the center of your circle. Then you need to place your circle in the correct position in Easel. Select the circle and under the shape tab select the center dot and put X and Y to 0.00. That will put the circle in the correct spot. PawPaw has a video on it. I attached an Easel file
https://easel.inventables.com/projects/ywEgT520ICmCFMm0Dul0pg
Russell
