I want to change the baud rate on my XCP. To be honest, I’m a little miffed that a change like this was made at all. It locks us out of using OpenBuilds Control. And I’m not too fond of the idea of reverting back to a previous version of the firmware, because that is asking for old bugs to reappear.
Yes, until you change it back.
The firmware is open source, so you can change it whenever you want to whatever you want. Unfortunately, it’s a compile time option which means you have to edit and reflash the firmware each time.
All closed. And that brings up another weird issue. If I do open up Easel, it connects to the machine just fine. Makes me wonder if it automatically uploads the newer firmware or changes the baud rate.
It should be able to connect then.
I’d try unplugging USB, closing all applications, plugging USB back in and then open OpenBuilds.
If that doesn’t work, restart computer.
Looking above… Did you change any windows settings?
Don’t think that would do anything unless there’s an update, but it won’t hurt.
I wonder if the XCP string after the hecyk welcome message is causing an issue…
