I set my work zero and proceeded to cut my project after about 3+ hours the rough cut was finished… But the cutter didn’t return to work zero instead it went about 1/4 inch past the zero point toward the front. now I’m not sure to reset the zero as before or use this new position.
How did the roughing carve turn out? It sounds like you might have lost some steps during the carve…
{:0)
Brandon Parker
