If I do a project in Vectric V-Carve using two or more bits on the project can I bring it into Easel, using G Code? Will Easel still allows the ability to stop and change bits?
In Vectric you create individual toolpath for each bit. Then import individually into easel.
Correct, when you export, you can group the files by the bit size.
Thank You, Folks, much appreciated.
Frank
