Changing drill bits
Hey guys, this might be a silly question but I’m still learning! Can you use different dude drill bits on one artwork?
In one Easel design you can use two different end mills.
You can copy an Easel design and assign two more end mills for the job.
Use the search tool and look for “two stage carve” and you will find a lot of good info about this.
Thank you guys! I will check it out:)
