Changing F speed mid file
Yesterday I decided that it would be a good learning experience to slow down the F speed towards the end of a carve in order to stop the bit chatter. Opened the G code file in a text editor and found that every move command line ends with F2500, it is my understanding that the F number only needs to occur one time until it needs to be changed why is Easel putting it on every line?
I think Grbl post processors don’t mind it that way. You can open your gcode in wordpad or notepad and Find/Replace a number(s) easily. Then save it.
