Any one have a good source to buy ecentric spacers for cheap?
Seeing these eccentric nuts have been designed for use with Makerslide based constructions, I doubt you’ll get them anywhere but from Inventables.
If you had a lathe and lots of free time, you could always make your own.
I have found them elsewhere…just not much cheaper than inventables.
LIst of vendors here: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
Misumi sells eccentric bushings: http://us.misumi-ec.com/vona2/detail/110300424410/ and if one is inclined one can make one’s own: DIY Eccentric Spacers for less than 40c each
if only i had free reign on the machines I use at work…I would have some done in about an hour…lol
I like this approach! I’ve just bought a 4 jaw chuck for the lathe which will be more accurate than the drill press. Another project…
Here you could order also.
Grtz Koen
Where I got my last batch:
http://www.ebay.com/itm/152176470284?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I stand corrected! I really didn’t think that these would be available from an alternative manufacturer.
I have enougheccentric spacers/nuts to last me but what I really need are more t-nuts.
Doesn’t ship to Australia…
But I found a seller on Banggood that does. 50 on the way $US6.
I got mine here because they are quite a bit more robust than the originals.
