Climb milling
Maybe a toggle switch to have the machine avoid climb milling
You need both depends on work pieces. Let say you need round cut and you want clean cut on round piece, you need climb carving. If you want that round piece to be waste and you need main part edges to be clean, this time you need conventional cut. This could be other than round. If you need to have any inner piece to be clean cut, you need climb cut.
Yes. A toggle switch to chose climb/conventional/auto. That would be even more helpful
Never used Easel, preview screen pushed me away, dislike it.
It seems on some cuts mine has done climb when it revered direction during a cutout
