Climb versus Conventional cutting
Up until now I have not paid much attention to the direction the tool was traveling. But now that I am beginning to understand more I have noticed a big difference, If I am doing a climb cut I get a lot of tool chatter. So my question is when should climb cutting be used (I am thinking never).
Is climb better with certain bits/end mills?
Some of what I have read says that a climb cut will give a better finish, but with all the chatter I am not seeing that at all.
Does feed rate need to be adjusted based on climb vs conventional?
I think climb milling requires larger endmills (like 1/2"), and a very rigid setup.
I always use conventional, like hand router way. Gives smother edges. Like Chris says, if you’re using larger bits or surface cleaning you may go with the climb. I think. Let see what others says.
When i cut aluminum i just do what gwizard tells me and it almost always turns out fine.
