looking for clipart that can be used for inlay, most 2d vector clipart that have found look like cartoons
what type of art are you looking for?
kitchen thing fruits veggie things that could be used as inlay in cutting board, bread boxes, ect
That’s a tough one, after looking around at clip art sites and google images (inlay cutting board) I couldn’t really find anything.
yes the same here I found a lot of 3d vectors but not ready to start try my hand at that… Thanks for looking
Try this site http://www.online-convert.com it will convert a picture to a SVG file.
Also check out this thread Where are the online patterns?
If you search google for SVG images you can find a lot of things. If you can’t get SVG, use a bit map and trace it with Inkscape (or similar tool - VCarve has that capability but it costs $$).
I think there is a “market” for clean SVG files ready for milling and engraving…
-Tom
I regularly use Inkscape to translate jpg, png, anything else to SVG. There is a command to “Trace Bitmap” that works surprisingly well in converting black/white images to BitMap, which can be saved as an SVG/EPS and imported into Easel or V-Carve.
