The link does not seem to work any more. Did you remove the step by step guide?
Thanks for checking! All I seem to be able to get is the Inventables login page. No matter how many times I click on that login button (multiple computers and browsers) it will not allow me to view the page even though I am actually logged in.
Sounds like a bug maybe. If you are using Internet Explorer (or Edge) try Chrome or vice versa. Hope this helps.
It’s not working for me either (Chrome). I get directed to the login page for Inventables (even though I’m already logged in). I tried logging out and again, same thing. Then used a different browser (Safari) with a clean cache. Same thing :-/ I read your writeup before and thought it was great! Guess it may be a bug in the site…?
Contact Inventables. They are pretty quick to respond. Maybe you need to create a new account?
I am having the same problem. Just get the log in page…and it is a login p;age that will not die, just keeps returning to the login page again and again.
I’m seeing that same log-in prob too despite already being logged in and able to post to the forum right now
Have you guys reported this?
Yes, I did report this awhile ago. Inventables just got back to me. Here’s their response:
The project isn’t publicly shared by the owner. There is a checkbox users can check if they want the project to be shared with the public. They would need to check that and save it. Here’s a screenshot (attached).
Unfortunately since this is a customer’s project, they are they only ones capable of making the project public. You might consider sending them a personal message to see if they can check that box.
Could you check the settings on the project?
Very nice work. My X-carve’s on order now and am enjoying all the great projects people have worked on! Thanks for sharing.
Oh believe me I am. Easel, Fusion 360 and more. Any recommendations are welcome.
I did see the check box and it is now checked. I got a lot of responses from the project. I don’t know how they could have gotten to see it if it wasn’t checked before so I am thinking it got changed some where. Can you see it now?
Yep, I can see it now. Thanks!
What’s add, is I use to be able to see it. I had it booked marked.
Getting an error when following the software link… The software is now hard to find. All the links I have found are not working.
Just use jason dorie’s halftoner, like phil said
while you’re at it, send the dude a beer via paypal…
does anyone know how to center the carving to the material? when i imported g code to easel it looks like this …
That’s not showing material in Easel when you import gcode, it’s showing the max range for your project. You need to set your origin/material size in the software you used to generate the code.
ok . I’m using halftoner 1.7, i noticed when i change the width to a certain number then go over to change the height , the program will change the width to a different number on its own. why is that ? example, i was typing in 11.75 for height and 14.75 for width of material. after i did that it changed on its own to something different . i didn’t know it until i went back to halftoner and looked .
