I bought this controller and I have communicating to the openbuils software but it will not communicate wi5th Easel. I am wondering if anyone else has the CNC xPRO and what did you have to do to make it work with easel?
have you downloaded and installed the Easel Driver?
yep
I wouldn’t recommend using with easel anyway. You can download your gcode and list it with openbuilds sender.
That said, it shouldn’t be a problem connecting with the xPro. Make sure you close openbuilds and anything else that might be using the port.
Well I am having problems with the openbuilds software. I can get it to communicate and able to jog the XYZ axis corredtly but when I tried to home the Z goes the exact reverse no matter what direction I got Z set to, so I imagine the x and y axis with got to the left front instead of the back right.
And I am a total noob when it comes to grbl, but I found the fix for the reverse homing problem which I will try tommorow. I just dont know about getting my xPro to communicate with easel.
Be careful going back and forth. Easel will overwrite settings on your controller if you’re not careful.
What machine do you have?
I have the OX from Bulk-MAN 3D and I am using the xPRO V5 controller
