I am trying to combine two projects in easel and only carve the outline. I don’t see a combine
tab in the edit tab. Is this still able to be done?
Yes, You have to select 2 or more objects for the Combine tab to show up.
Select the 2 objects you want to combine then go to Edit and scroll down to
Combine or you can hit Ctrl J for a shortcut.
