Well since the dewalt611 is basically on back order, what other compatible routers can be use on the xcarve ?
Makita RT0701 (need shimming as the diameter is 3mm less (about 1/8")) compared to the Dewalt.
Powerwise its identical but have two added benefits over the Dewalt:
- Lower minimum RPM of 10k vs Dewalt 16k
- Longer brush life before brush replacement is required
Amazon has a MILLION 611 routers.
Yeah but once you go to buy it tells you they are back ordered
The Dewalt 611 Routers are on B/O from Amazon. You can order them from Lowes, or Home Depot. If you need one asap, I was able to pick one up quick at Grainger, or MSC Industrial Supply if you have one of these industrial stores in your area.
