Hi, i am having issues with easel homing, if i jog or manually move the machine to work piece starting position, i need to reset the arduino so that it thinks that this is my home position.
i assume the button that says confirm home position is supposed to do this step for me once i have got the cutting head to my starting position.
in machine inspector the DRO dose not set work position once the home position button is pressed,
apart from this everything works well.
i am using aurduino, grbl shield v3, 0.8c
$0=5.000 (x, step/mm)
$1=5.000 (y, step/mm)
$2=25.000 (z, step/mm)
$3=10 (step pulse, usec)
$4=7500.000 (default feed, mm/min)
$5=4000.000 (default seek, mm/min)
$6=96 (step port invert mask, int:01100000)
$7=255 (step idle delay, msec)
$8=150.000 (acceleration, mm/sec^2)
$9=0.100 (junction deviation, mm)
$10=0.050 (arc, mm/segment)
$11=100 (n-arc correction, int)
$12=3 (n-decimals, int)
$13=0 (report inches, bool)
$14=1 (auto start, bool)
$15=0 (invert step enable, bool)
$16=0 (hard limits, bool)
$17=1 (homing cycle, bool)
$18=108 (homing dir invert mask, int:01101100)
$19=500.000 (homing feed, mm/min)
$20=1000.000 (homing seek, mm/min)
$21=100 (homing debounce, msec)
$22=1.000 (homing pull-off, mm)
